JetHub H1
Standard support
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 313.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Kernel: 6.18.33, Size: 328 MB, Release date: Jun 24, 2026
In order to boot Armbian from JetHub H1 with pre-flashed OS on eMMC you need USB-USB cable and do:
  1. Download Amlogic Burning Tool
  2. Download latest burnable firmware (testing branch)
  3. Flash!
More instructions on https://wiki.jethome.ru/en/jethub_h1#controller_firmware
Now you can boot Armbian from eMMC.
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Minimal/IOT images with Armbian Linux v6.18
Build Date: Jun 24, 2026
Distro Variant Extensions Torrent Integrity Size
Resolute Minimal / IOT SHA    ASC 316.8 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 328.7 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.18
Distro Application Torrent Integrity Size
Debian Testing (Sid) SHA    ASC 544.1 MB
Debian Testing (Sid) Kali Linux SHA    ASC 542.6 MB
Debian 13 (Trixie) SHA    ASC 528.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 528.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 439.1 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 439.2 MB
Debian 13 (Trixie) SHA    ASC 1.2 GB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Specifications
Amlogic S905W
FAQs
Simple
Universal
Minimal, server or Desktop. We work with XFCE, Gnome and Cinnamon but more is possible to build: Mate, KDE, Budgie, Deepin, i3, ...
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly. Insert the SD card into the slot, connect a cable to your network if possible or a display and power your board. (First) boot (with DHCP) takes a bit longer.
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
