helios4
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.6.123, Size: 283.1 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.5 Minimal / IOT
Kernel: 6.6.135, Size: 273.8 MB, Release date: Jun 24, 2026
  • OMV (OpenMediaVault) can be installed on Armbian Bookworm minimal with armbian-config -> software
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Minimal/IOT images with Armbian Linux v6.6
Build Date: Jun 24, 2026
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 258.8 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.6
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 486.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 478 MB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Become a partner and support development!
Specifications
1000tx 2 core 2GB 32bit ECC docker i2c sata spi flash usb3 wireguard Marvell A388
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.6
Distro Variant User space Kernel Torrent Integrity Size
Debian 14 (Forky) Minimal / IOT rolling 6.6.143 SHA  ASC 265 MB
Resolute Minimal / IOT stable 6.6.143 SHA  ASC 275.8 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
