espressobin
Community maintained
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 298.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.5 Minimal / IOT
Kernel: 6.12.83, Size: 312.4 MB, Release date: Jun 24, 2026
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
  • Version 7 EspressoBIN (identifiable by sata power connection instead of molex) has ethernet ports in the reverse order.  This can be fixed in armbianEnv.txt with the line “fdtfile=marvell/armada-3720-espressobin-v7.dtb”
  • manual flashing to latest u-boot is mandatory, again (as part of 2022.05 release)! Download the right boot flash for your board: 512,1G,2G, number of RAM chips (identify by visual inspection – one on each side of the PCB opposite to each other. Later 1GB models have only one chip at the bottom) and appropriate memory speeds. You can obtain numbers from the current boot prompt. Also choose right memory: ddr3 are for V3-V5 EspressoBin’s (i.e. V5, 1g-2cs) and ddr4 images are for v7 EspressoBin’s. Insert ‘ddr3’ or ‘ddr4’ into the bubt command string. Copy this flash-image-{ddr3,ddr4}-MEM-RAM_CHIPS-CPU_DDR.bin to your formatted USB key, plug it into USB3.0 port and execute from u-boot prompt:
    bubt flash-image-ddr3/ddr4-MEM-RAM_CHIPS-CPU_DDR.bin spi usb
    In case you experience instability reflash boot loader with lower CPU speed values!  SoC speed can be found printed on the armada chip, under the heat sink.  No 1200 chips have been reported, 800 is a safe option, 1000 is a likely option.  It can also be found as part of the current u-boot output.
  • Updated u-boot (2022.04) needs new default boot environment and boot script. U-boot now respects ethaddr and eth[0,1,2]addr variables. This is what you need to copy/paste into u-boot prompt:
    printenv ethaddr
    env default -a
    saveenv
    # Including this line to make sure saveenv is executed.
  • If ethaddr was previously changed, it can be set with “setenv ethaddr f0:ad:4e:08:00:00”, then “saveenv”
  • If you manage to crash your SPI flash, get appropriate files and proceed with one of the rescue options: SATA, UART,
  • if you need USB2 port on your mPCI slot (for Bluetooth or 4G/LTE modems) you need to move both jumpers near to the USB2 port. Position for this function is: away from the port.
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Minimal/IOT images with Armbian Linux v6.12
Build Date: Jun 24, 2026
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 279.1 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.12
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 564 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 550.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 428.4 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-config utility to adjust your system settings
Specifications
1000tx 2 core 2GB 64bit docker eMMC i2c mpci sata spi spi flash switch usb3 wireguard Marvell A3700
FAQs
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly. Insert the SD card into the slot, connect a cable to your network if possible or a display and power your board. (First) boot (with DHCP) takes a bit longer.
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
Rolling releases images with Armbian Linux v6.12
Distro Variant User space Kernel Torrent Integrity Size
Debian 14 (Forky) Minimal / IOT rolling 6.12.94 SHA  ASC 345.8 MB
Resolute Minimal / IOT stable 6.12.94 SHA  ASC 315.2 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
