cubieboard2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 729.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.8.0-trunk.170 Minimal / IOT
Kernel: 6.18.35, Size: 270.2 MB, Release date: Jun 24, 2026
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Use armbian-install utility to transfer live image to fixed storage
Specifications
100tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s nand sata spi wireguard Allwinner A20
FAQs
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly. Insert the SD card into the slot, connect a cable to your network if possible or a display and power your board. (First) boot (with DHCP) takes a bit longer.
