cubieboard2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 729.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 270.2 MB, Release date: Jun 24, 2026
100tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s nand sata spi wireguard Allwinner A20
