la-frite
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.15, Size: 305.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
SPI bootloader update:
  1. Download the firmware update file.
  2. Flash the file to a USB drive
  3. Eject the drive from your computer and plug it into La Frite.
  4. Power on La Frite and it will start updating the firmware.
  5. Do not power off La Frite until the firmware update is complete!
USB Mass Storage Flashing:
  1. Connect La Frite to the host PC with a USB A to USB A cable
    • This is the USB connector closest to the IR sensor and 40 pin connector
    • The other will not work
  2. Connect a USB keyboard to the remaining port on La Frite
  3. While booting, press the <Esc> key to get the boot menu on the device
  4. Select “eMMC USB Drive Mode”.  La Frite will appear as a USB drive on the host PC
  5. On host PC, flash the desired image to the drive.
  6. Disconnect the USB A cable from La Frite (important), reboot
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Desktop images with Armbian Linux v6.18
Build Date: Jun 24, 2026
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Minimal/IOT images with Armbian Linux v6.18
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 294.3 MB
Resolute Minimal / IOT SHA    ASC 318.1 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.18
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 563.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 569.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 429 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-config utility to adjust your system settings
Specifications
100tx 4 core 64bit docker i2c spi flash wireguard Amlogic S805
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
