la-frite
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.15, Size: 305.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
SPI bootloader update:
  1. Download the firmware update file.
  2. Flash the file to a USB drive
  3. Eject the drive from your computer and plug it into La Frite.
  4. Power on La Frite and it will start updating the firmware.
  5. Do not power off La Frite until the firmware update is complete!
USB Mass Storage Flashing:
  1. Connect La Frite to the host PC with a USB A to USB A cable
    • This is the USB connector closest to the IR sensor and 40 pin connector
    • The other will not work
  2. Connect a USB keyboard to the remaining port on La Frite
  3. While booting, press the <Esc> key to get the boot menu on the device
  4. Select “eMMC USB Drive Mode”.  La Frite will appear as a USB drive on the host PC
  5. On host PC, flash the desired image to the drive.
  6. Disconnect the USB A cable from La Frite (important), reboot
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 294.3 MB
Resolute Minimal / IOT SHA    ASC 318.1 MB
Debian Testing (Sid) Kali Linux SHA    ASC 563.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 569.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 429 MB
100tx 4 core 64bit docker i2c spi flash wireguard Amlogic S805
