Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 258.1 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Desktop images with Armbian Linux v6.12
Build Date: Jun 24, 2026
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Minimal/IOT images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 252.5 MB
Resolute Minimal / IOT SHA    ASC 260.7 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.12
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 516.3 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 512.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.2 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-install utility to transfer live image to fixed storage
Specifications
Allwinner H616
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.18
Distro Variant User space Kernel Torrent Integrity Size
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 265.9 MB
Resolute XFCE stable 6.18.36 SHA  ASC 761 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
