Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 258.1 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 252.5 MB
Resolute Minimal / IOT SHA    ASC 260.7 MB
Debian Testing (Sid) Kali Linux SHA    ASC 516.3 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 512.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.2 MB
Allwinner H616
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 265.9 MB
Resolute XFCE stable 6.18.36 SHA  ASC 761 MB
