Rock5 ITX
Standard support
Desktop
Armbian 26.5.1 Gnome
Kernel: 6.1.115, Size: 1.1 GB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 288.4 MB, Release date: Jun 24, 2026
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Desktop images with Armbian Linux v6.18
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Distro Variant Extensions Torrent Integrity Size
Resolute Gnome SHA    ASC 1.1 GB
Resolute KDE Plasma SHA    ASC 1.5 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Resolute KDE Plasma SHA    ASC 1.4 GB
Minimal/IOT images with Armbian Linux v6.18
Resolute Minimal / IOT SHA    ASC 318.4 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 314.8 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Resolute Minimal / IOT SHA    ASC 289.6 MB
Dedicated applications images with Armbian Linux v6.1
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 543.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 547.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.5 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Specifications
Rockchip RK3588
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.1
Distro Variant User space Kernel Torrent Integrity Size
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 291.4 MB
Resolute Gnome stable 6.1.115 SHA  ASC 973.6 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
