Rock5 ITX
Standard support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 288.4 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Resolute Minimal / IOT SHA    ASC 318.4 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 314.8 MB
Resolute Minimal / IOT SHA    ASC 289.6 MB
Debian Testing (Sid) Kali Linux SHA    ASC 543.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 547.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.5 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 291.4 MB
Resolute Gnome stable 6.1.115 SHA  ASC 973.6 MB
