Standard support
Desktop
Armbian 26.2.1 Gnome
Kernel: 6.12.57, Size: 1.3 GB, Release date: Apr 25, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.57, Size: 303.4 MB, Release date: Apr 25, 2026
The SK-AM62P-LP starter kit (SK) evaluation module (EVM) is built around the AM62P display processor, which includes scalable Arm® Cortex®-A53 performance and embedded features, such as triple high-definition display support, high-performance 3D-GPU, 4K video acceleration, and extensive peripherals. SK-AM62P-LP is for those looking to develop automotive and industrial applications, including automotive digital instrumentation, automotive displays, industrial HMI and more.
SK-AM62P-LP includes multiple display connectors that enable supporting up to 3 screens, a mobile industry processor interface (MIPI®) CSI-2 camera connector, an M.2 connector for WiFi or Bluetooth modules, 2 Gigabit Ethernet ports, UART to USB circuit for debug output, and 2 temperature sensors for monitoring SoC and LPDDR4 thermal monitoring.
Features
  • Processing: AM625P with Quad 64-bit Arm Cortex-A53 up to 1.4GHz, two ARM Cortex R5F single core up to 800MHz
  • Display: dual display support with up to 3840p x 1080p display resolution, One dual-channel LVDS and one MIPI-DSI 4L. One HDMI connector over DPI/RGB444 with audio codec TLV320AIC3106
  • M.2 key E interface support for Wi-Fi® and Bluetooth® modules; two RJ-45 Ethernet 1000/100Mbps with TSN support
  • Connectivity: 1 Type-A USB 2.0, 1 Type-C dual-role device (DRD) USB 2.0 supports USB booting, onboard XDS110 Joint Test Action Group (JTAG) emulator, 4 universal asynchronous receiver-transmitters (UARTs) via USB 2.0-B
  • Storage: 8GB LPDDR4; bootable interfaces on SK; removable microSD, USB, quad serial peripheral interface (QSPI), Ethernet, UART
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Desktop images with Armbian Linux v6.12
Build Date: Apr 25, 2026
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Minimal/IOT images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 288.4 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.12
Distro Application Torrent Integrity Size
Debian Testing (Sid) Kali Linux SHA    ASC 519 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 535.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 425 MB
Debian 13 (Trixie) OpenHab SHA    ASC 1.2 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-config utility to adjust your system settings
Specifications
Sitara
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.18
Distro Variant User space Kernel Torrent Integrity Size
Debian 14 (Forky) Minimal / IOT rolling 6.18.13 SHA  ASC 321.4 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
