Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.57, Size: 303.4 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
The SK-AM62P-LP starter kit (SK) evaluation module (EVM) is built around the AM62P display processor, which includes scalable Arm® Cortex®-A53 performance and embedded features, such as triple high-definition display support, high-performance 3D-GPU, 4K video acceleration, and extensive peripherals. SK-AM62P-LP is for those looking to develop automotive and industrial applications, including automotive digital instrumentation, automotive displays, industrial HMI and more.
SK-AM62P-LP includes multiple display connectors that enable supporting up to 3 screens, a mobile industry processor interface (MIPI®) CSI-2 camera connector, an M.2 connector for WiFi or Bluetooth modules, 2 Gigabit Ethernet ports, UART to USB circuit for debug output, and 2 temperature sensors for monitoring SoC and LPDDR4 thermal monitoring.
Features
  • Processing: AM625P with Quad 64-bit Arm Cortex-A53 up to 1.4GHz, two ARM Cortex R5F single core up to 800MHz
  • Display: dual display support with up to 3840p x 1080p display resolution, One dual-channel LVDS and one MIPI-DSI 4L. One HDMI connector over DPI/RGB444 with audio codec TLV320AIC3106
  • M.2 key E interface support for Wi-Fi® and Bluetooth® modules; two RJ-45 Ethernet 1000/100Mbps with TSN support
  • Connectivity: 1 Type-A USB 2.0, 1 Type-C dual-role device (DRD) USB 2.0 supports USB booting, onboard XDS110 Joint Test Action Group (JTAG) emulator, 4 universal asynchronous receiver-transmitters (UARTs) via USB 2.0-B
  • Storage: 8GB LPDDR4; bootable interfaces on SK; removable microSD, USB, quad serial peripheral interface (QSPI), Ethernet, UART
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 288.4 MB
Resolute Minimal / IOT SHA    ASC 322 MB
Debian Testing (Sid) Kali Linux SHA    ASC 519 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 535.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 425 MB
Sitara
