Flashing instructions:
- Force device in maskrom mode – erase bootloader from Linux:
dd if=/dev/zero of=/dev/mmcblkX bs=1M count=8 conv=fsync
- General instruction for flashing with RKdevtools: https://docs.armbian.com/User-Guide_Getting-Started/#rockchip
- USB connection for RKdevtools: use lower port, near to SD card reader.
- Bootloader binary: https://fi.mirror.armbian.de/dl/mekotronics-r58hd/u-boot/rk3588_spl_loader_v1.08.111.bin
UART:
In case you are unable to enter maskrom mode, use UART and execute following command at boot loader prompt:
=> mmc dev 0 => mmc erase 0x0 0x2000
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Different images? Missing features? -> Download SDK Looking for compatible accessories? Want to participate in development?
Desktop images with Armbian Linux v6.1
Build Date: Jun 24, 2026
Minimal/IOT images with Armbian Linux v6.1
Bleeding edge images with Armbian Linux v7.0
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Resolute | Gnome | SHA | ASC | 1.1 GB | ||||||
| Resolute | KDE Plasma | SHA | ASC | 1.5 GB | ||||||
| Resolute | Minimal / IOT | SHA | ASC | 317.4 MB | ||||||
| Minimal / IOT | SHA | ASC | 316.5 MB | |||||||
| * Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that. | * Most of images are tested with test automation or by Armbian community or official maintainers. | |||||||||
Dedicated applications images with Armbian Linux v6.1
| Distro | Application | Torrent | Integrity | Size | ||||||
| Kali Linux | SHA | ASC | 548.3 MB | |||||||
| Home Assistant | SHA | ASC | 532.3 MB | |||||||
| OpenMediaVault | SHA | ASC | 406.6 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
| * 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support. | ||||||||||
Specifications
FAQs
- check previous images from archive
- join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
- Free support is provided via general project search engine, documentation, community forums or IRC/Discord. Keep in mind this is mostly provided by our awesome community members in a best effort manner and therefore there are no guaranteed solutions.
- For commercial or prioritised assistance:
- book a an hour of professional consultation,
- consider becoming a project partner.
- Reach us out at https://armbian.com/contact,
