mekotronics-r58-4x4
Staging Platinum support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 290.3 MB, Release date: Jun 24, 2026
Flashing instructions:
UART:
In case you are unable to enter maskrom mode, use UART and execute following command at boot loader prompt:
=> mmc dev 0
=> mmc erase 0x0 0x2000
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 289.8 MB
Bleeding edge images with Armbian Linux v7.0
Resolute Minimal / IOT SHA    ASC 317.4 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 316.5 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Debian Testing (Sid) Kali Linux SHA    ASC 548.3 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 532.3 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 406.6 MB
Rockchip RK3588
