bananapiplus
Community maintained
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 262.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 26.2.5 XFCE
Kernel: 6.18.24, Size: 891.9 MB, Release date: Jun 24, 2026
For proper hardware support you need to edit /boot/armbianEnv.txt and add:
fdtfile=sun7i-a20-bananapi-m1-plus.dtb
following by reboot.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 936.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 253.1 MB
Resolute Minimal / IOT SHA    ASC 269.9 MB
Debian Testing (Sid) Kali Linux SHA    ASC 501.3 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 500.2 MB
1000tx 1wire 2 core 32bit CAN UASP battery bluetooth docker i2c i2s sata spi wifi wireguard Allwinner A20
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 280.4 MB
Resolute XFCE stable 6.18.36 SHA  ASC 730.6 MB
