bananapim2s
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.15, Size: 306 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 26.2.5 XFCE
Kernel: 6.18.24, Size: 1000.3 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 297 MB
Resolute Minimal / IOT SHA    ASC 318.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 564.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 575.1 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 430.8 MB
Amlogic S922X
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 321.8 MB
Resolute XFCE stable 6.18.36 SHA  ASC 820.7 MB
