bananapim2u
Community maintained
Desktop
Armbian 26.2.0-trunk.792 XFCE
Kernel: 6.18.24, Size: 826.1 MB, Release date: Apr 25, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.792 Minimal / IOT
Kernel: 6.18.24, Size: 281.4 MB, Release date: Apr 25, 2026
1000tx 1wire 2GB 32bit 4 core CAN UASP battery bluetooth docker eMMC i2c sata spi wifi wireguard Allwinner R40
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
