bananapim4zero
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 280 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Bluetooth is currently broken.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 257.3 MB
Resolute Minimal / IOT SHA    ASC 283.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 549.1 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 533.1 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 387.9 MB
Allwinner H616
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 286.3 MB
Resolute XFCE stable 6.18.36 SHA  ASC 764.3 MB
