- powering with PD capable PSU is not possible. It has to be dumb 5V
- To change display resolution, add below to the /boot/armbianEnv.txt:
extraargs=video=HDMI-A-1:1920x1080M@60
Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| XFCE | SHA | ASC | 1.1 GB | |||||||
| * Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. | ||||||||||
| Minimal / IOT | SHA | ASC | 296.5 MB | |||||||
| Resolute | Minimal / IOT | SHA | ASC | 317.2 MB | ||||||
| Kali Linux | SHA | ASC | 566.6 MB | |||||||
| Home Assistant | SHA | ASC | 557.2 MB | |||||||
| OpenMediaVault | SHA | ASC | 433.5 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
10000tx 1wire 4 core 4GB 64bit Closed bootloader UASP docker eMMC i2c usb3 wireguard Amlogic S905X3
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 320.9 MB | ||
| Resolute | XFCE | stable | 6.18.36 | SHA | ASC | 820.3 MB | |
