bananapim64
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 779.4 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 281.7 MB, Release date: Jun 24, 2026
  • Some devices powers off on load
1000tx 2GB 4 core 64bit UASP battery bluetooth docker eMMC i2c wifi wireguard Allwinner A64
