bananapim7
Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 293.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 291.7 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 314.6 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 299.2 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 321.6 MB
Resolute Minimal / IOT SHA    ASC 314.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 289.6 MB
Resolute Minimal / IOT SHA    ASC 286.6 MB
Debian Testing (Sid) Kali Linux SHA    ASC 542.6 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 539.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 397.2 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 292.3 MB
Resolute Gnome stable 6.1.115 SHA  ASC 982.6 MB
