Community maintained
Minimal
Kernel: 6.12.82, Size: 266 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
All download options
10000tx 1000tx 4 core 4GB 64bit aarch64 docker eMMC m2 mpci usb3 Mediatek
