cubieboard1
Community maintained
Minimal
Kernel: 6.18.35, Size: 271.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
100tx 1wire 32bit CAN battery docker i2c i2s nand sata spi wireguard Allwinner A10
