- Boot log for 25.5.1: https://paste.armbian.com/ehuwawexih
- Gigabit Ethernet transfer rate is around 50% of its theoretical max rate (internal chip bus limitation)
1000tx 2 core 2GB 32bit 4 core 4GB SPDIF bluetooth esata wifi wireguard NXP Freescale i.MX 6
- join community forums
