inovato-quadra
Standard support Platinum support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.18.33, Size: 980.4 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 281.3 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 280.3 MB
Debian Testing (Sid) Kali Linux SHA    ASC 548.2 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 548.8 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 405.6 MB
H6 Allwinner
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 277.3 MB
Resolute XFCE stable 6.18.36 SHA  ASC 762.1 MB
