JetHub D1
Standard support
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 321.6 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Kernel: 6.18.33, Size: 322.8 MB, Release date: Jun 24, 2026
In order to boot Armbian from JetHub D1/D1+ with pre-flashed OS on eMMC you need USB-USB cable and do:
  1. Download Amlogic Burning Tool
  2. Download latest burnable firmware
  3. Flash!
More instructions on https://docs.jethome.com/controllers/linux/din_rail/index.html
Now you can boot Armbian from eMMC.
All download options
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 323.7 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 324.2 MB
Debian Testing (Sid) SHA    ASC 549.5 MB
Debian Testing (Sid) Kali Linux SHA    ASC 553.3 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 417.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 408.8 MB
Debian 13 (Trixie) SHA    ASC 1.2 GB
100tx 1wire 2GB 4 core 64bit aarch64 bluetooth docker eMMC i2c wifi wireguard Amlogic A113X
