Standard support Platinum support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.1.115, Size: 353.1 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
  1. copy your OS image into any removable storage SD / USB Flash , etc (formatted by exfat or ext2/3/4 or fat)
  2. start OOWOW by press FUNCTION + RESET
  3. exit from wizard
  4. plug removable storage with OS image
  5. choose this image to write by menu → Write image to eMMC and up to .. mounts
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 371.6 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 381 MB
Resolute Minimal / IOT SHA    ASC 352 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 342.8 MB
Resolute Minimal / IOT SHA    ASC 323.3 MB
Debian Testing (Sid) Kali Linux SHA    ASC 526.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 535.2 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 405.7 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 329.7 MB
Resolute Gnome stable 6.1.115 SHA  ASC 1.1 GB
