khadas-vim1
Standard support
Minimal
Armbian 25.11.1 Minimal / IOT
Kernel: 6.12.58, Size: 277.6 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
To be able to boot Armbian SD card image and install Armbian to eMMC, use one of the methods to boot into upgrade mode. If you have most recent board revision (1.4 ->) then you only need to quickly press the function key (middle) 3 times in 2 seconds. Release and boot will proceed from SD card. Then use nand-sata-install utility to flash to eMMC.
Serial console:
Blue color line: Tool Pin TXD, orange color: Tool Pin RXD, black: Tool Pin GND
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 286.9 MB
Resolute Minimal / IOT SHA    ASC 319.4 MB
Debian Testing (Sid) Kali Linux SHA    ASC 571.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 554.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 431.5 MB
100tx 1wire 2GB 4 core 64bit bluetooth docker eMMC i2c i2s usb-c wifi wireguard Amlogic S905X
