khadas-vim3
Standard support
Minimal
Armbian 25.11.1 Minimal / IOT
Kernel: 6.12.58, Size: 334.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
In order to boot Armbian from VIM3 with pre-flashed OS on eMMC you need to:
  1. Download Khadas Rescue tool for VIM3 and flash it to a spare SD card
  2. Insert SD card, attach USB keyboard + monitor or a serial console and boot into Khadas Rescue Tool
  3. Choose: Advanced -> eMMC -> Fast erase and Advanced -> Erase SPI Flash (Yes). Go back and select "power off"
Now you can boot Armbian from SD card and install to eMMC the standard way.
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 324.3 MB
Resolute Minimal / IOT SHA    ASC 354.7 MB
Debian Testing (Sid) Kali Linux SHA    ASC 558 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 563.1 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 425.3 MB
1000tx 1wire 4 core 4GB 64bit bluetooth docker eMMC i2c i2s m2 pci spi spi flash wireguard Amlogic S922X
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 360.6 MB
Resolute XFCE stable 6.18.36 SHA  ASC 918.3 MB
