Standard support
Minimal
Armbian 25.11.1 Minimal / IOT
Kernel: 6.12.58, Size: 253.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 241.2 MB
Resolute Minimal / IOT SHA    ASC 269 MB
Debian Testing (Sid) Kali Linux SHA    ASC 522.8 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 509.4 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 365.6 MB
NXP Freescale
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 259 MB
Resolute Gnome stable 6.18.36 SHA  ASC 953.5 MB
