mekotronics-r58s2
Staging
Minimal
Armbian 26.2.2 Minimal / IOT
Kernel: 6.1.115, Size: 338.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Product page: https://www.mekotronics.com/h-pd-108.html
To install Armbian you have to use rkdeveloptool.
The guide can be found here: rkdeveloptool flashing guide
Testing results Armbian 26.05
Kernel Vendor 6.1.115
Boot 🟢 Works (U-Boot 2026.04)
HDMI 🟢 Works
Ethernet 🟢 Works
WiFi 🟢 Works (150-200mbps download / 40 mbps upload)
Bluetooth 🟢 Works
GPU 🟢 Works
Audio 🟢 Works (tested via HDMI)
USB 🟢 Works
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 327.6 MB
Resolute Minimal / IOT SHA    ASC 357.8 MB
RK3588 Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 349.6 MB
Resolute Gnome stable 6.1.115 SHA  ASC 982.8 MB
