Additional information
Details about the MKS Klipad50 board and Sovol’s KlipperScreen:
- Hardware details
- Implementation status in Armbian images
Github project with issue tracker, discussions and custom images:
Flashing instructions:
Build Date: Jun 24, 2026
| Kali Linux | SHA | ASC | 529.5 MB | |||||||
| Home Assistant | SHA | ASC | 531.6 MB | |||||||
| OpenMediaVault | SHA | ASC | 463.3 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 364.3 MB | ||
| Resolute | Minimal / IOT | stable | 6.18.36 | SHA | ASC | 358.8 MB | |
