Standard support Platinum support
Desktop
Armbian 26.5.1 Bianbu
Kernel: 6.6.100, Size: 1.7 GB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 289.7 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Debian 13 (Trixie) Minimal / IOT SHA    ASC 287 MB
SpacemiT K1
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 300.7 MB
Ubuntu 24.04 (Noble) XFCE stable 6.18.36 SHA  ASC 761.9 MB
