Build Date: Jun 24, 2026
| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Resolute | Minimal / IOT | SHA | ASC | 317.3 MB | ||||||
| Minimal / IOT | SHA | ASC | 317.9 MB | |||||||
| Kali Linux | SHA | ASC | 544 MB | |||||||
| Home Assistant | SHA | ASC | 542 MB | |||||||
| OpenMediaVault | SHA | ASC | 399.3 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.1.115 | SHA | ASC | 291.3 MB | ||
| Resolute | Gnome | stable | 6.1.115 | SHA | ASC | 978.7 MB | |
