nanopia64
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 758.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 267.4 MB, Release date: Jun 24, 2026
1000tx 1wire 4 core 64bit battery docker i2c spi wifi wireguard Allwinner A64
