nanopidou2
Community maintained
Minimal
Kernel: 6.18.35, Size: 274.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
  • Serial console is enabled by default on µUSB
100tx 1wire 32bit 4 core CAN UASP bluetooth docker i2c spi wifi wireguard Allwinner H3
