nanopiduo
Community maintained
Minimal
Kernel: 6.18.35, Size: 273.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
  • Onboard wireless module (XR819) has poor software support so wireless connection issues are expected
  • Hardware issues which manifest in stuck on reboot/power off on some boards (fix)
  • Serial console is enabled by default on µUSB
100tx 1wire 32bit 4 core CAN UASP docker i2c msata spi wifi wireguard Allwinner H2+
