nanopik2
Standard support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.18.35, Size: 1020.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.35, Size: 320.1 MB, Release date: Jun 24, 2026
  • temperature readings are wrong. In reality, they are 15-20° lower
  • eMMC booting is not supported
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 321.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 566.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 556.7 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 430.5 MB
1000tx 2GB 4 core 64bit bluetooth eMMC wifi wireguard Amlogic S905
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 321.3 MB
Resolute XFCE stable 6.18.36 SHA  ASC 821 MB
