nanopim4v2
Standard support
Desktop
Armbian 26.5.1 XFCE
Kernel: 6.18.33, Size: 1010.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 308.3 MB, Release date: Jun 24, 2026
  • UART is accessible on a standard connector but with unusual speed: 1500000
  • If you don’t have USB Type-C PSU, you can power the board via pins 4 (5V) and 6 (GND) of the 40-pin GPIO1 header
  • Powering related troubles are possible since USB Type-C is not PD-compliant. In fact you have to use dumb 5V PSU or device won’t boot up.
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 294.3 MB
Debian Testing (Sid) Kali Linux SHA    ASC 575.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 548.5 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 430.9 MB
1000tx 1wire 4GB 6 core 64bit UASP bluetooth docker eMMC i2c m2 pci spi usb3 wifi wireguard Rockchip RK3399
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 319.1 MB
Resolute XFCE stable 6.18.36 SHA  ASC 801.7 MB
