Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.Desktop images with Armbian Linux v6.1
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.Minimal/IOT images with Armbian Linux v6.18
Most stable mainline based kernel but not all features have been implemented yet.| Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
| Resolute | Minimal / IOT | SHA | ASC | 295.2 MB | ||||||
| Minimal / IOT | SHA | ASC | 318.8 MB | |||||||
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.Dedicated applications images with Armbian Linux v6.1
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.| Distro | Application | Torrent | Integrity | Size | ||||||
| Kali Linux | SHA | ASC | 542.9 MB | |||||||
| Home Assistant | SHA | ASC | 506.7 MB | |||||||
| OpenMediaVault | SHA | ASC | 408.2 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.1.115 | SHA | ASC | 284.1 MB | ||
| Resolute | Gnome | stable | 6.1.115 | SHA | ASC | 973.3 MB | |
