nanopineo2black
Community maintained
Minimal
Kernel: 6.18.35, Size: 275.5 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
1000tx 4 core 64bit UASP docker eMMC i2c wireguard Allwinner H5
