nanopineoair
Community maintained
Minimal
Kernel: 6.18.35, Size: 270.9 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c spi wifi wireguard Allwinner H3
