Community maintained
Minimal
Kernel: 6.18.35, Size: 279.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
1000tx 1wire 4 core 64bit UASP docker eMMC i2c i2s spi wireguard Allwinner H5
