nanopineo
Community maintained
Minimal
Kernel: 6.18.35, Size: 280.2 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
100tx 1wire 32bit 4 core CAN UASP docker i2c spi wireguard Allwinner H3
