These images are designed for the R3S LTS model, but due to minimal differences, they are fully compatible with the non-LTS variant as well.
Build Date: Jun 24, 2026
| Kali Linux | SHA | ASC | 569.4 MB | |||||||
| Home Assistant | SHA | ASC | 560 MB | |||||||
| OpenMediaVault | SHA | ASC | 427.6 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 319.6 MB | ||
| Resolute | Gnome | stable | 6.18.36 | SHA | ASC | 1012.9 MB | |
