nanpi-r4s
Standard support
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.18.33, Size: 294.8 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Kernel: 6.18.33, Size: 316.6 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Debian Testing (Sid) Kali Linux SHA    ASC 521.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 534.9 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 430.7 MB
1000tx 4GB 6 core 64bit UASP bluetooth docker usb-c usb3 wifi wireguard Rockchip RK3399
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 319.1 MB
Resolute Minimal / IOT stable 6.18.36 SHA  ASC 316.7 MB
