nanopir6
Standard support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 289.1 MB, Release date: Jun 24, 2026
If you are having a NanoPi R6C variant, replace fdtfile=rockchip/rk3588s-nanopi-r6s.dtb in /boot/armbianEnv.txt with fdtfile=rockchip/rk3588s-nanopi-r6c.dtb
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Resolute Minimal / IOT SHA    ASC 291.8 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 314.2 MB
Resolute Minimal / IOT SHA    ASC 274 MB
Debian Testing (Sid) Kali Linux SHA    ASC 524.9 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 536.6 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 380.8 MB
Compatible
Nanopi R6C
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 282.9 MB
Resolute Gnome stable 6.1.115 SHA  ASC 976.7 MB
