Standard support Platinum support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 280.8 MB, Release date: Jun 24, 2026
Flashing instructions:
    1. Hold MASK button and power the device up to enter MASKROM mode
    2. You will need mini loader binary for this device https://dl.armbian.com/nanopi-r76s/bootloader/MiniLoaderAll.bin
    3. Follow instruction for flashing with RKdevtools: https://docs.armbian.com/User-Guide_Getting-Started/#rockchip
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 288.1 MB
Bleeding edge images with Armbian Linux v7.0
Resolute Minimal / IOT SHA    ASC 316.9 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 318.9 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Debian Testing (Sid) Kali Linux SHA    ASC 546.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 546 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 380.3 MB
Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 278.5 MB
Resolute Gnome stable 6.1.115 SHA  ASC 976.2 MB
