In case you are experiencing reboot troubles, make sure to update u-boot. How? Run this command as root:
armbian-install -> "Update bootloader"
Build Date: Jun 24, 2026
| Kali Linux | SHA | ASC | 555 MB | |||||||
| Home Assistant | SHA | ASC | 570.6 MB | |||||||
| OpenMediaVault | SHA | ASC | 434 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
1000tx 1wire 4 core 4GB 64bit UASP docker eMMC i2c i2s spi usb3 wireguard Amlogic S905X3
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 321.1 MB | ||
| Resolute | XFCE | stable | 6.18.36 | SHA | ASC | 812.1 MB | |
